Make: Nissan
Model: Skyline HR31 Gts-x
Milage: ~80,000
Transmission: 5 speed manual
Colour: Black/Silver
Complied? Yes
RWC supplied? No
Currently registered? Yes
Price: $12,500 Firm
Contact: Karl - [email protected]
Comments / Modifications:
Engine
RB24DET bottom end
Tomei 82mm pistons
RB26DET crank/rods
1.2mm Tomei stainless HG
fully Rebuilt Cyl Head
Splitfire coilpacks
rebuilt R33 RB26DET injectors
Apexi Power FC + HC
Z32 AFM
Custom Garrett 2871R with RB25det Rear
HKS cast low mount manifold
3" exhaust incl custom dump
R33 GTR cooler
Trust BOV
Turbosmart boost controller
Suspension
Bilstien shocks
King springs
Whiteline front 24mm adjustable swaybar
custom Whiteline rear adjustable camber kit
Hicas removed
Tien camber tops
All nolythane bushes front/rear
Brakes
R33 GTS-T rotors and calipers all round
Braided lines all round
DS2500 brake pads
Motul fluid
New master cylinder
Cusco master cylinder stopper
Driveline
Fresh Rb20det gearbox
Extreme HD clutch (under 1000km since new)
1.5Way LSD diff (getting noisy)
Interior
HKS gauges - Oil temp and pressure
Greddy turbo timer
Power FC hand controller
Alpine HU
JVC front splits
Pioneer 6x9s
Thats about all i can think of at the moment.... :D
Images:
As you can see loads of money has been spent, super quick car with shitloads more potential left in it. Has made 230rwkw on 17psi with a fairly conservative tune, Throw an external gate and bigger rear housing on the 2871 and it'll make even more, but i enjoy the huge mid-range torque so kept the 33 housing.
I've owned the car since importing it from Japan 4 years ago and have spent too much to bother counting..
Reason for selling is i've bought an Evo IX and its just taking up garage space at the moment.
All test pilots and low ball offers will be ignored. PM or email me with serious offers.
Edited by kwazza11
https://www.sau.com.au/forums/topic/228836-hr31-skyline-gts-x-24-stroker/
Has Z31 Californian turbo front hubs, so 5x114.3, the rears are still the 4 stud stock hubs however ANY 5 stud rear hubs off a Z31 are a straight bolt on, i've never bothered converting the rear because both sets of rims i use are multistud. Rear hubs can be purchased from most wreckers for -$100 (what can i say? i'm lazy..)
I'll get some more pics up tonight but interior pics will have to wait till next week as i'm currently interstate on work.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
