atmospheric BOV's sound heaps better, especially when you hit fullboost and release throttle and hear this almighty TSCHHHH come from the car, is much better than having a goddamn muztek style dose lol
I don't think atmo bov's have any performance value since it's venting the aircharge into the bay, but i like the sound of mine at least, so yeah, guess its a personal preference for the noises you like to hear out of your car lol.
You could block your standard BOV i.e. with a piece of sheet metal.
My mate's R32 is running a fairly big turbo without a BOV, so as the air recirculates through the compressor housing it makes a HUGE whistle/chirp sound, sounds like feeding an air compressor through a massive flute.
When he's on my right and my window's down he changes gear and splits my f**ken ear drum open. My ears nearly bleed.
Good times :thumbsup:
Stock is the smart decision
But if you must have an atmospheric bov, the novelty wears off and you eventually feel like an idot, not to mention it will hurt if you get a yellow sticker, anyways go with a turbosmart i think they sound the best. This may hurt the hks fans but DONT get a hks ssq they sound crap like a large high pitched whistle but it is a very popular choice. So obviously i am different in taste in that aspect.
But i would deffinetly reccommend a stock bov.
Get an after market one, its a novelty everyone wants at first.
Yes, they certainly are a novelty...
My R31 ran with no BOV, FMIC and apexi pod filter and made the filthiest fluttering noises you've ever heard. Sounded fantastic.
I've tried the blanking plate on my R33 and the ECU does NOT like it. Pops and farts like crazy on gear changes, so I went back to standard. With the BOV blocked it definitely felt crisper on gear changes but the extra backfires meant it wasn't worth it.
Well if you want that back if you get it tuned with apexi pfc to suit it will run fine
You can never get even a PFC l-jetro to run fine without a BOV, as the fluttering load cells are the same cells that you see at cruise, so you can only tune it to suit one of the conditions... runs rich on gearchanges
Kinks how does my daily ride have any bearing on a thread about blow off valves? begone troll.
I hate dosing, just makes me think of wankers in VL Turbos, and the noise gets grating on my ears very quickly.
Mine's a Turbosmart Supersonic BOV, I like the sound, and the cops around here have never given a toss about it, and yes ive let it off near them accidentely, but chances are if they are pulling you over to defect you they're going to make something up if they dont find anything anyway. Having the stock crossover pipe helps, if I ever did get defected for it, its easy to swap with the stocker.
Can't find a video of anything that sounds like it, needless to say it dosen't sound like one of those godawful Blitz (or was it HKS? high pitched whistle) ones which sound like something from Need For Speed.
Edited by bozodos
I'm due for a new BOV as my standard one leaks like a sieve (and yes I have tryed the "no more leaking BOV mod" to all you smarties with your stock BOV's)
I'll go a turbosmart plumbback, Hopefully it'll be quite.
I used to think the BOV noises were pretty cool, but after seeing (rather hearing) every other Tom, Dick and Harry with one on there piece of shit I don't want a noisy one.
I hate it when people put them on there car to trick you into looking at there Daihatsu's and other pieces of crap.
Is the BOV rooted? If the spring isn't tensioning the diaphragm properly put the BOV in a vice and crush it down a little. That will increase spring tension, meaning more boost needed to force it open.
I've read about doing this on SAU, haven't tried myself (but the 'stop leaking BOV' mod worked a treat :blink: ) so if your car turns into a fireball blame the shonky b**tard that originally said it.
kthxlater
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
