Hi Mate :) all this tuning remotly was idea of Anthony:) firs i didnot belive that we can do anything but he made this:) tommorow am going to track and with anthony we will try to tune FC, so than i will post up results and pictures and give you all the details what you need:)
thanks again to Anthony ;) )) am going to stick your picture on my rides hood:))
airbrush job would set it off nicely! :D
  • Replies 90
Have you ever seen Anthony? I don't think that's something you want to advertise :D
But yeah, this is quite ground breaking Anthony :)
no have not ;) but if he can tune it for me is no metter :))
Should be just clicking into 4th :D
This wireless tuning your doing is awesome! Keen to hear how it goes
Haha yeah, pretty much your at the end of 3rd, the gearing on bikes is insane. Your doing well over 120 in first, havn't really ever seen the max it pulls in first as normally the wheel is in the air and the last place you wan't to be looking is down at the speedo..
tuned his car, got rid of all the knocking.. injectors are at 100% duty cycle :down: and i had to send him off to re-gap his spark plugs to .7 gap.
its a bit slow and a little frustrating but ive worked on slower remote controll sessions before so i cannot complain.
Thanks to you:) i could not tell bye because of battery of laptop and deposite of cell phone:) i have bought new spark plug gap them all to 0.6 and car runs perfectly:) no even one knocking level no flashing of engine light and no misfire or backfire:) perfect job !!!! thanks a lot mite :D best goal is KKR 480 now boosts at 3800 RPm instead of 4800 :D boost eraund 16 psi i will make run tonight to check time at 1/4 mile:)
thanks again mate i will make post here for remotly tuning over the sea:)))
excelent job
thank
thaks
thanks :D))
Guilt troy, I'm shopping for power fc. And I'm asking for an opinion. I can get a rb25powerfc for about 1200-1300usd. I got z32 afm already. Now I can get rb26 pfc for around 800usd l-jetro or d-jetro. Which one should I go though ? If I go rb26 d-jetro I could save lots of money :devil: Just don't want to save here to get bad results everywhere. So I'm asking for opinion. Thanks!
Thanks to you:) i could not tell bye because of battery of laptop and deposite of cell phone:) i have bought new spark plug gap them all to 0.6 and car runs perfectly:) no even one knocking level no flashing of engine light and no misfire or backfire:) perfect job !!!! thanks a lot mite :devil: best goal is KKR 480 now boosts at 3800 RPm instead of 4800 :D boost eraund 16 psi i will make run tonight to check time at 1/4 mile:)
excelent job
thank
thaks
Cool mate :) im glad it all worked out well. I will be looking forward to seeing the pics and videos of your race track while tuning it. at least you know now your engine is not going to detonate itself to pieces :)
It was 42deg when he was going around the track, i can imagine how much he was sweating when changing the plugs on a hot engine bay. Did you test out the high timing map or low one ? the hot or cold one?
post results :)
Guilt troy, I'm shopping for power fc. And I'm asking for an opinion. I can get a rb25powerfc for about 1200-1300usd. I got z32 afm already. Now I can get rb26 pfc for around 800usd l-jetro or d-jetro. Which one should I go though ? If I go rb26 d-jetro I could save lots of money ;) Just don't want to save here to get bad results everywhere. So I'm asking for opinion. Thanks!
allways get the RB25 power fc if it is available. less hassles that way and you know its going to run properly.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
