  • Replies 665
Posted Images
YALL GON MAK ME LOOSE MY MIND, UP IN HER, UP IN HER
anyways Adrian put down a seperate order for me for:
Hoodie
Black
no username
Medium
$50 fitty dowlah.
Edited by Damo_R34
Sorry Ruby, this is for Adrians benefit:
Good work Adrian AND DAMO :thumbsup:
hoodie/jacket: JACKET
username/real name: RUBY
name in caps or not: CAPS
colour: BLACK
how many: 1
Will make the transfer tomorrow, clear by Thursday
Extra: might as well get one for the missus
username/real name: RUBY's GIRL
colour: BLACK
how many: 1
hoodie/jacket: Hoodie
name: Cronic... (including the dots)
name in caps or not: no caps
colour: black
how many: 1
colour: Black
how many: 1
Transferring the $$ now, will PM you
hoodie/jacket: HOODIE
username/real name: GRAHAM_R32
colour: BLACK
how many: 1
=$56
username/real name: R32_SKYLINE
colour: ROYAL
how many: 1
=56.60
plus $10 for postage
Total of $122.60
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
