  • Replies 665
Posted Images
with all the people stressing out over their hoodie in this thread I think an SAU walking stressball group buy should be next before the next hoodies orders :domokun::domokun::devil:
HAHA I would buy that!! :domokun: Do they come in other colours? How much can we get them for in a group buy? :cool:
black probably be best and it was something like $7-$9 each with walking legs... and about $4-$5 each for ones without walking legs...
hmmm and is that with or wihout the SAU logo? I guess the legs makes it ideal as a desk ornament :domokun: Or dash mounted...for times of frustration in peak time traffic!
Edited by N-DAWG
Lets not forget the SAU Stress Ball Launcher!!
http://www.tshirtgun.com/
Each cannon also comes standard with 2 vinyl logos at no additional charge, and custom graphics and designs are available at an additional charge.
ok so the hoodie thread, i have signed and faxed the final proof, printing is due to start today/monday!
Well done guys! Take our impatience as a sign of a job well done :D We just wanna be proud to be SAU
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
