Hey guys,
I have an Impul front bumper ( the damged one, has now been fixed and in primer))
but ive called 3 shops in redcliiffe (( one of which fixed my damage from when someone keyed it))
and yet, they have all quoted a amount i didnt think possible just to paint a front bumper..
one quoted 400.. but subject to change when inspected, the ther 385 ( again subject to change) and the last quote 550 (( all said thats jsut painting the bumper, not fitting etc etc (( it came off a SAU members car so fitting is not an issue for me)
now im sorry i cant see how a simple spray and colour match can cost that much...
so can anyone recommend to me somewhere that is sensible yet does a fantastic job?
or is this simply what it costs to paint a front bumper???
thanks in advance,
Bryn
https://www.sau.com.au/forums/topic/229628-paint-and-panel-shop/
lol, nah ill keep it dan :P impul is fibreglass, so i dont think ill keep it long, and i dunno how many times i can convince my brother to keep fixing it hahaha
besides, isnt ya R34 front bumper the better one, with the fog lights in it? :thumbsup:
lol, nah ill keep it dan :) impul is fibreglass, so i dont think ill keep it long, and i dunno how many times i can convince my brother to keep fixing it hahaha
besides, isnt ya R34 front bumper the better one, with the fog lights in it? :D
You mean fog-light holes.....the lights were gone when the car arrived hahaha
3 or 4 yrs ago you could get a front bar resprayed for around $200...unfortunately as with everything else the cost of labour has gone up significantly as well.
Tried DMD or Camerons bodyworks or JEtspeed in Slacks Creek? If you want a proper job then I reckon $300-$400 is quite reasonable.
I got cameron to quote on spray painting my bootlid and fixing up some rust and welding up the holes for the wing last year and that was quoted at close to $600.
Edited by n15m0
the reason its so much is cause its fiberglass, im a painter n seriously there a prick to work on, there full of pin holes n wavey and you cant put heat on them cause it makes them warp n crack.. i primed and blocked a monkey warehouse (considered good quality) 180sx BN front bar 4 times and it still looked dodgey.. its just one of those things where its worth someone doin it properly.. where are you located? we dont like doin them but we like workin on good cars so yeh
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
