Hello guys, i'm going to get my timing belt replaced soon. Rang up Nissan and it costs $102 for the belt. I just wanted to confirm the part no. before i go and buy it.
The part no i have is 13028-20P25, I have a na R33 93mdl. Also figured i'd get the ac belt and Alt/fan belt changed too.
AC Belt 11720-77A00
Alt/fan belt 11720-42L02
Has anyone changed these recently and can confirm them?
Also, is it true that the RB30 water pump will fit straight in?
Cheers
https://www.sau.com.au/forums/topic/23044-timing-belt/
most places sell the timing belt for 90-120 bucks.
you can pick up a fancy trust/greddy belt for 300 odd but i dont think thats needed.
time taken to do the change is 3-4hours pending on experience of person.
other belts worth changing at the same time, theres two i think, they cost about 30bucks together.
https://www.sau.com.au/forums/topic/23044-timing-belt/#findComment-494097
ok guys i have bought the timing belt for $102 from nissan.
the alternator belt is about 32 and the power steering about 35 and the ac about 17.
im going cheap and getting the aftermarket ones for those.
ac belt - 4PK910
ALT - 4PK850
PWR ST - 3PK845
repco and stuff seem to only have the one 5mm longer eg 4PK915 etc. not sure if that will fit. but they can order it in.
https://www.sau.com.au/forums/topic/23044-timing-belt/#findComment-495197
ive got my timing belt here, it came off a 94' GTS R33.
Nissan 13028 20P10 141T
i dont think the timing belt would be 40bucks, that seems too cheap. the cheapest i found was 80 odd bucks from justjap.
there is 142, (plus or minus 1, lost count) bumps or ridges on the timing belt.
https://www.sau.com.au/forums/topic/23044-timing-belt/#findComment-495202
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
