hey all just bort an r34 gtt 4 door and was installing a deck when i found a black switch hidden under the handbrake cover. its a black nissan switch with a steering wheel in the middle and sais on and off. its still connected but there is no place where it sits, and when i flick it there is a small tick sound in the dash. any ideas?
https://www.sau.com.au/forums/topic/230658-wats-this/
nah mate its manual bin trying to find it on google and stuff but still nothin and from what i can tell i dont think its been converted from an auto either
On your dash - can you still see the P R N D down the center? In manual models this area will be blacked out. Another way of telling if your car was an auto is if your steering wheel has + and - buttons (assuming your still using the stock steering wheel).
https://www.sau.com.au/forums/topic/230658-wats-this/#findComment-4055332
LOL its the switch to turn on teh tiptronic gear changes on the steering wheel, so if ur car is manual, someone has used a auto part in the car, or its been converted to manaul
but yeah what iseecool said
https://www.sau.com.au/forums/topic/230658-wats-this/#findComment-4056431
thanx for the answers guys.
it doesnt hav the p r n d down the centre of dash and
tiptronic buttons on the steering wheel + its still stock.
and Silver_R34_GT-T what do u mean they have used
an auto part in the car? im assuming it dont do anythin?
https://www.sau.com.au/forums/topic/230658-wats-this/#findComment-4056829
  • 4 weeks later...
yeah i told you what it was mate, 100%, if u can here it ticking, then your car was auto, and it has had a manual put in...
what i meant by replace something, ( i miss read) i thought u meant under teh shroud it was in the plastic ( as in they had used a plastic part of dash from the auto) not that it was hidden my bad)
we didnt need a picture as the description you gave about the button was spot on.
how did you go with the vin fast?
i tell you what, if i had paid for manual only to find it was originally auto id be pissed...
https://www.sau.com.au/forums/topic/230658-wats-this/#findComment-4107633
yeah man had it fasted and aparently it was an auto :(
but they did a good job of it, dash and steering wheel,
everythings been changed. also had it checked out by
a mechanic and they recon it was a good job done on
it and well taken care of it only 1 small leak :) .
so im not too pissed about it except they km's are fake,
but i guess they are in most anyway
https://www.sau.com.au/forums/topic/230658-wats-this/#findComment-4114995
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
