Make : Nissan
Model : 1998 R33 GTST S2, 40th Aniversary Edition
Milage : 75, xxxkm
Transmission: Manual
Colour : White
Location : Central Coast-Gosford (or Castle Hill for work)
Complied? Yes
RWC supplied? Umm, what's this? It's registered
Currently registered? Yes (11 months)
Price: $17,500
Contact: 0413 189 488 (Birnie)
Comments / Modifications:
The car makes a very stable 245.9 rwkws but at the time, it had a sliping clutch which you can see on the top of the dyno graph where it gets a little jaggedy, that'd be the clutch jumping around a bit.
This has since been replaced with an awesome, genuine Exedy kit designed for the GTR so it can really take a pounding if you wanna upgrade further.
Also, the plugs were gapped down to 0.65mm to stop the misfiring. This also has been adressed with replacement Splitfire coilpacks, and the plugs returned to 0.8mm. Zero misfires! :blink:
I might get it back on the dyno and see if the clutch and splitfires make a difference to the top of the curve, and maybe crack the 250rwkws :D
The car has been tuned by The Hitman in Penrith.
Most people have heard of him and his reputation. Excellent!
It has a very standard look apart from the the Apexi Rev Speed Meter and a Blitz Boost Gauge.
The car is in excellent condition.
I had it inspected before I bought using Sydney Vehicle Checking Company.
They gave it a well above average rating and said that it's unusual to find these cars in this condition with NO rust and NO panel damage. So I bought it.
...if you haven't heard of them or used them before, they go over every panel with a magnet tester looking for signs of bog/rust etc...
It was bought from a fellow who imported it just to make a buck, which was fine by me, so I am the 1st Australian road registered owner.
Never been dragged (althouhg i'd like too), but has been to the Wakefield Raceway once when it was on the standard turbo on 7psi (4 yrs ago). And I'm no race driver so it's had a pretty easy life.
Other people with the HKS2535 have made mid 12's on the drag.
Robo's (i think) had mid 12's on the 2530 and then made low 12's on the 2535
( http://www.skylinesaustralia.com/forums/PB...5-s-t74271.html , this is his 2530 thread with the 2535 reult in his signature )
Time to downgrade unfortunatley and get some cash for house reno's :)
Also 5yrs ownership and me getting older, it's time to move on.
ENGINE
Apexi Pod Filter
Apexi Power FC (inc hand controller)
Apexi Power FC Boost Control Kit (18psi/1.3bar, other preset values 0.8, 1.00 and 1.15bar)
Turbo - HKS2535 with pirtek braided lines
Injectors - S15 480cc (max 80%)
AFM- - Z32 (genuine Nissan delivered from Japan)
Fuel Pump - Tomei replacement kit - Posts #38 onwards below
( http://www.skylinesaustralia.com/forums/R3....html&st=20 )
Full 3" Exhaust, cat back/cannon is genuine HKS
TRUST FMIC
Splitfire coilpacks
SUSPENION/WHEELS/BRAKES
Whiteline Springs with Bilstein shocks (refurbishable)
DBA4000 slotted up front
Bendix Ultimates - Front Pads
Winmax - Rear Pads
17x8(235's) and 17x9(255's)
DRIVELINE
Genuine Exedy kit (from Kudos Motorsport), GTR style which can take heaps more power than what I'm making
Pics to come....
I to have this turbo on my R33 and am very happy with it its a very resposive turbo and fits under the standard heat shield :laugh: Good luck with the sale mate
Edited by OZ_Pomy
  • 1 month later...
  • 5 weeks later...
this is depressing, I have exactly the same car (40th anniversary), similar mods
sucks to be trying to sell a skyline now :P hopefully stuff will pick up when the interest rates drop a bit
Well, front wheels off......pulled out the old Bendix Ultimates.....hand on a sec!
There's still half left!
Back in they go and someone gets an extra set of pads for a good sale. :down:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
