Make: nissan
Model: r32 4 door gts
Milage: 180xxx
Transmission: manual
Colour: silver
Complied? yes
RWC supplied?no
Currently registered? no
Price: $8000ono
Contact: 0421576676
Comments / Modifications: extractors, pod
Images:spa0304yp2.th.jpg spa0307zi0.th.jpg
car has been through regency once but didnt pass due to small 1 inch diameter rust hole and some bushes
car can pass regency if these 2 things are repaired/replaced no doubt..
can take rims off to make car cheaper..
https://www.sau.com.au/forums/topic/230937-r32-4-door-gts/
is a bit pricey.......if you could get it thru regency id see if you swap for a C33 laurel with a cefiro front, turbo auto. if your wonderin wat it looks like got to carsales. its an un finished project.
https://www.sau.com.au/forums/topic/230937-r32-4-door-gts/#findComment-4085670
