I'm Goin For A Drive *sunday 7th September*
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 186
Posted Images
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
11. Michele & Mark - I'll just have to bring a photo of the open wheeler so she doesn't feel left out.
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
17. TURISMO (is gay)
18. naughtyruski
19. SteadyEddie
20. a20089 (for even numbers sake)
21. Kat
22. bnr32t (only if it rains, good drift weather)
Edited by BNR32t
it's cos you spell his name wrong
well since like EVERYONE is going I dont want to feel left out so I might as well come too :)
warning: I will be tired and grumpy on a few hours sleep so dont piss me off hehe
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
18. naughtyruski
19. SteadyEddie
21. Kat
23. Shell
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
18. naughtyruski
19. SteadyEddie
21. Kat
23. Shell
24. Sl33py (said he was interested)
Im starting to think you dont like me Kieth
LoL, well you did spell my name wrong...
I was told to kick you the other day... lol. (something to do with your rims)
PS. bring on the motorkahana... :whistling: This time i have the poor tyres.
haha, finally had a look at the route. Should be hilarious with the 28, i literally cannot accelerate up hills in any gear above 2nd... Probably best if i sit at the back, also theres that whole Toyota thing aswell :whistling:
So there is a chance someone will get done for speeding? Serious??? :P
Goddamnit.... :D i have enough problems with defects and D's following me to worry about!! I just had yet another Dickson inspection again...
Can't say for sure what chicks go through with a gynaecologist, but i felt violated.. :)
