check out the classifieds section of the site, and all of the traders too, one of them will mostly likely have them, or at least a replica on their site
http://www.skylinesaustralia.com/forums/Cl...fieds-f137.html
These ppl are the Authorised Dealers in AUS as listed in the C West Japan Website.
EVO Motorsport PTY LTD
96 Newcastle Street, Fyshwick
ACT 2913, Australia
Tel: 02 6228 1222
Fax: 02 6280 9050
email: [email protected]
Trading Hours:
Mon - Fri 8:30am - 5:00pm
Sat: 9:00am - 4:00pm
