hello all... simpole questiopn that has been bothering me for ages and ages!!!/..... where do i go in he s/e suburbs of melbourne to get the blue nice looking silcon joins for my cooler piping...and at that... where do i go to get those high pressure clips.. i think they are called makele clamps... the ones that you tighten a nut on the bolt apposed to the shitty python hose clamps...thankyou guys
https://www.sau.com.au/forums/topic/231164-silicon-joins/
autobarn and super cheap stock the usual 2.5" and 3" but if you after 2.25" or 2.75" then you will need to check out some of places nismoid mentioned, i got my 2.75 from purple pig.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/231164-silicon-joins/#findComment-4060087
weld them up??? dude...then how do ya get the piping out when ya need to?? plus the silicon piping looks sick!!! the stuff is expensive as though... i guess everything like this is on these cars.. heheh.. cheers boys
Well obviously you dont weld them all up but i probably should of spelled that out hey :P
There is no reason why you cant weld up the bottom half of your piping which gets rid of 2 silicon joins and you can still take the piping off without a problem :P
https://www.sau.com.au/forums/topic/231164-silicon-joins/#findComment-4060346
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
