My C210 radiator is leaking... so maybe it's time to grab a shiney aluminium one from ebay or what have you. There is plenty of Z and later model nissan stuff coming out of Hong Kong and the states, however nothing specifically for my car. Anyone else know what will bolt straight up besides 240k? I'm thinking likely suspects are R30, 280zx perhaps others. Anyone know for sure?
Cheers!
https://www.sau.com.au/forums/topic/231356-radiator-interchangability/
Cheers!
The one out of my wrecked MR30 was to wide to fit my C110,
what width is the one in your car ?
I could measure it for you
Nigel
Drew, I took one to a radiator place the other day to get flushed as I destroyed the one I had in the car when the fan flexed. The guy told me it was a V8 holden one.
The stampings are as follows ADRAD 12 HOL 950 24102. bottom outlet is the same and for the top inlet you can get a hose to suit.This radiator was in the 4 door donor car I bought. This is about to have twin thermos attached then placed into my coupe. Hope this helps. Ricky
Thanks - that's interesting to know. My radiator is 68cm wide by 50cm high. The bolt holes are about 66cm by 25 cm. If you are in drivers seat looking towards the front of the car the hoses connect to the top right and bottom left of the radiator. The hoses connect perpendicular to the radiator - they aren't coming off at strange angles or anything.
D
My first car was a C210. I never had any real problems with overheating (Even with ac). Unless your running heaps of compression I would have the stock one reconditioned. It you find the right workshop, they will put a better core in it!
Pretty sure the old-school radiators connect top-passenger-side, bottom-driver-side, which is opposite to what you have described.
Drew, I'm inclined to agree with blind elk regarding the inlet/outlet. Any way my bolting up holes are quite similar. Both radiators I have are different, according to the radiator guys one is a 6 cylinder holden and the other is V8 holden. both are from HQ to HX roughly but they both fit. You may have to redrill some hole, mine has a few different holes already.Both measure approx 68cm x50cm. Ricky
You're right about the hoses. Im just cross-eyed. The radiator is leaking from the bottom of the radiator itself, not the core, which is a bit odd. I chucked a nasty spare radiator in there for the time being, but will keep an eye out for a better long-term arrangement. My C210's have had a history of sweating a little at 110km/h on hot days.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
