Item:ARC super induction box for ECR33
Age: used
Condition: in great nick,
Price: $300.00 (nengun is $476.00 delivered!)
To Fit: (What car) R33 gtst
Contact: PM me
Comments: Dropping in a RB26 so not needed..
its an arc pannel, air comes in from the top just like your normal box. you might wanna modify the original snorkel for better cool air induction. they are a tight fit with standard IC pipes, well mine is. very nice induction noise compared to pods.
  • 3 weeks later...
I've got one on my 32 and love it! i couldn't source a panel and from memory they can be a bit $$$ so did a "mcgyver" and coverted it to foam style (but is easily changed back). Awesome sound out of it and won't get you defected by the tossers in blue!
GL with the sale mate :D
do u have any pics of it while u still had it in the car champ??? just wanna see how much of a tight squeeze it would be with IC piping there
Hi,
do you still have it... I've been thinking of putting in a K&N pod with cold air piping down to where the SMIC used to be, but... The girlfriend will go ballistic if I spend anymore money on the car... So... How much would shipping be to Adelaide (5044)
Alex
  • 3 weeks later...
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
