Hey Guys,
I had to remove my backseat, to get my parcel tray and 6x9s out of my car so that the rear window can be tinted. At the moment im driving my car around with no backseat. Is this illegal? can i be defected or anything like that?
Obviously no one is sitting back there, but i ama bit concerned it i get pulled over.
Cheers,
https://www.sau.com.au/forums/topic/231766-legal-o-not/
Nah its not.. as long as you've still got the 3 belts in the back then its fine.. I got pulled over a few months ago with no back seat and the HWP guy didnt mention anything about it.
Previously I've been pulled over with a metal bar mounted across the back seat (vid camera mount), and the cop said that if I want to keep it there i've gotta re-engineer the car as a two seater because its not safe for people to sit back there with the bar there. The back seat is just comfort/padding so I cant see why it'd be illegal to have it removed.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4068951
You do know they can tint your windows these days without having to remove your backseats and parcel tray..
It's amazing what they can do these days!
They have been doing this for years :O
yea i always wanted to know if you could get defected for no back seats.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4068973
Maybe his 6x9's are mounted on spacers which locate them close to the rear window almost touching.
I had to remove my 7x10's for rear window tinting as mine pretty much touched the rear window.
Dude,now that you got the speakers out,just throw the backseat back in if your worried(i would be)
On a r32 its just 2 or 3 clips and 2 bolts.
EDIT: spacers,i knew it!
Edited by FATAZZ
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069007
speakers sat to high up... almost rubbing on the window... you know spaces and all? Amazing what people assume...
Oh and thanks for the info... is good to know.
Well if someone else is doing it.. Why don't you let them worry about the problem. That's what you are paying them for.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069018
Because im a bit tight and didnt want to pay extra for them to do that. also didnt trust them taking everything out without breaking anyhing.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069030
it is illegal unless the car is registered as a 2 seater even if the seat belts are still there, ive been defected a few times for it on the way back from the track
Edited by reaper
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069585
hang on now i'm confused. when i took my back seats out to install my stereo, i made some enquiries and called a place to get an approved certificate, and they asked, what part of the body am i changing? and i replied with nothing, i'm just adding MDF and fibreglass to the back and they said it was fine. my seat belts are out, my rear pillars have tweeters in them, and nobody has ever said anything...?
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069647
This is correct.
Im pretty sure its a red defect and carries points (2 or 3) if you take out your rear seat belts even if no one is in the back seat..
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069897
^ Totally agree with the above.. Illegal unless registered as 2 seater..
Prevents fully sick drifters driving around with stripped out cars.
doesnt prevent it just requires money spent on a blue slip for it to be legal
removing rear seats gives me alot more room for tyres its not just about making it lighter :thumbsup:
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4070145
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
