Just after feed back on Melbourne's Public transport.
Being more specific I will be looking to catch the train from Sydneham to Flinders st station in the morning around 6:40am, then from Flinders st onto the Sandringham line.
Being from Sydney, the transport up there is quite bad, Trains are all over the place, so I drove almost everywhere. I hear Melbourne is much better but to what extent I don't know.
Do many people here have problems getting to work on time?
Do either of these lines have bad "reputations"?
Cheers
Bluey
Edited by bluey33
https://www.sau.com.au/forums/topic/231831-public-transport/
lol the Sandringham line is the pits dude, one of the worst :thumbsup:
There is at LEAST one service cancelled per week between 7am-8:30am.
Usually more like 2-3 in a week, and sometimes more than one in the 7am-8:30am block. (ive had two in a row a few times)
2 days outta 5 i get shafted is my 'average' for Sandringham, simple as that. Yet the connex stats would 'say' otherwise.
Trains are always late out of Flinders St in peak hour (morning/night) and thats going both ways. Fken gives me the shits. Its all because its a single line so if one train is late, your stuffed :)
Gotta wait for the next one unlike shared lines where you have a few options.
End of the day, regardless of the shafting, its still cheaper (and faster if i dont get shafted) than driving to work and i live less than 5kms from the CBD.
iused to catch the train to work due to lack of parking near my work but it's not good, some mornings there would be 3 trains in a row not running and most the time they ran late, i gave up after a while and just drove, i figured if it took me longer to drive at laest i would be warm and have a seat, turns out it's alot quicker to drive and no where near as annoying
My other option is the tram from flinders to stop 43 Brighton rd/Glen Huntley
This may take longer "by the timetable" though if there are less hassles it may benefit.
I am trialling the journey tomorrow morning and then again Thursday to see how I go.
I worked out driving to be close to $100/week + toll Versus $20 zones 1+2.
On a 1st year wage I will try to catch the train as much as possible
PT in melbourne has improved a LOT lately
try it out and see how you go
im on the train after many many years and im impresssed
its very reasonable, cheap and vary rarely do they cancel services
they have KPI's to adhear to these days so they cant just privatise it and do whatever
187? damn bush and his war!
I p/t once or twice a week though its not the sandy line so i cant comment but on average its been pretty good but dont be surprised if there is a delay. if you need to be punctual then i suggest to get the earlier train to what you had planned.
I've caught PT to work for ages due to not having a car spot for the R....the good points are that it gets me to where I need to go and it is cheap. The bad news is that trains get cancelled/delayed (esp relevant if you are trying to make another train/bus or whatever) and trains in peak hour are so packed that you might have to let a couple go before you can get on.
Overall the system is way more extensive than say sydney and you can pretty much get everywhere you need to go, but don't expect german/japanese timekeeping :)
Hey mate,
Don't know if you have sussed it out yet but here is the metlink page and should help you out a bit.
Just don't fare evade because you will have to take the person out for tea that is paying for fare.
http://www.metlinkmelbourne.com.au/
Cheers. I have found out which Routes I can take, the point of this topic was just peoples experiences on how reliable it is.
I start my new job on Monday and I will be going by train. I will start getting there earlier at the start until it becomes 'acceptable' to blame the train and take the risk of hoping they run on time :)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
