I have a a stupid question, ive just installed a fmic. It didnt cum with a pin/connection for my boost cont welded in i found out after i started putting on the piping. Ive bought a little valve that i just screw into the piping from autobarn, the problem is cos ive never taken notive really of which pipe it went into on the stock one, i dont know which pipe i need to drill and tap it into. Can someone please tell me or show me a pic. Is it the one that goes from the turbo?
Please be gentle to me
https://www.sau.com.au/forums/topic/232117-embarrasing-question/
but wouldnt the cold pipe see actual pressure after any drop through the cooler?
no. lets say you do put it on the cold pipe, eg: say you loose 1psi through your cooler, and you boost controller is set to 12psi, your turbo will actually be making 13psi, because of the pressure drop. you want your boost controller seeing the pressure that the turbo is making, thats why you put it on the hot side fairly close to the turbo.
cheers for that
But wouldn't it be better to have the boost controller seeing exactly what pressure is reaching the manifold... I mean I don't particularly care if my turbo is making 13PSI if the engine only sees 12... the 12 is what I want to limit yeah?
you will care if your pushing the limit of the standard turbo, or any turbo for that matter. in then end you want your turbo producing the desired level of boost, and all the pipes and intercooler to have little effect on the overall pressure, you want the system to be the least restricting it can be, ie: using quality coolers with low pressure drop ratings.
The problem with controlling boost via the pre intercooler pressure is that boost will slowly drop off at high rpm. Why? Because no matter how good it is, the intercooler and pipework will suffer some pressure drop. Plumbed into the pre-intercooler pipework, the wastegate actuator will not be receiving the actually boost pressure, hence the drop off at high rpm (actually airflow).
Cheers
Gary
QWK32 - Hrrm, I think I disagree. The turbos a means to an end, it just moves air up against the intake valves, a location I care more about regulated pressure then out the comp outlet of the turbo. Assuming your not constrained by turbo outlet pressure (stock ceramic) I think maybe the pressure there is borderline insignificant.
OP - For a manual BC, I'd take it from close to the TB. For a EBC, I would take the closed loop boost sender feed from same location, though take the wastegate feed from close the compressor outlet.
Its kinda moot in most setups Id say, and depends on the specifics. If you are boost limited by a stock turbo (and going along with boost/heat kills em) then the feed taken from the comp outlet would be the way to go, to insure you don't go over 13psi (or woteva it is)
If your motors tuned close to the limit with a aftermarket turbo and built motor and you know you start to det on a hot day at 24psi... well then the a TB/plenum source is the go.
Hope that made sense... 2 of them even:)
Ok, so im getting my bro in law to weld it to the piping, i have a turbosmart t-boost which i will be getting rid off soon for a ebc. I have a power fc - untuned atm, stock turbo, exhaust and now the fmic. I was guna get it welded off the turbo but as i am getting the ebc soon and the tune, what you are saying is that im better of getting it on the outlet piping so i think ill go that way. I didnt think it would cause this much of stir seeing as this is a turbo forum and i assumed people on here would have them in pretty much the same location as being the best position for them all.
Thank you
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
