Hi guys,
As I wrote in my previous post, my mechanic told me that my cam actuator in my car is stuff, and to fix it, I can either replace the part with a standard part or I can get adjustable cams and it will fix the problem as well.
Anyway, I am not very knowledgable regarding cams, I go not idea about size, angle etc etc.
Basically, this is what my mechanic proposed: "The price for the 260 pon cam's $1200.00 and the gears are $600.00 for the pair"
I was reading in another thread that the size and or what ever it is may be too agreesize for my car and I wont get much power increase.
I currently push out 273 rwkw with a GT2835 Pro s turbo. I wanted to hit the 280 rwkw mark with these cams but I am not sure if what I am getting is what I should be.
Also, does the price sound right for those cams?
What brand are pon cams, are they tomei?
Any help would be greatly appreciated as these are getting installed in my car on Tuesday so I need to know if they are the correct application for my car or if there is something else you guys suggest>???
Thanks guys!
https://www.sau.com.au/forums/topic/232273-r33-turbo-cams-help-needed-please/
Adj cam gears to purchase are like $150. $650 is a very... interesting price... even including labour.
As for 273 vs 280rwkw, who cares? You wont notice 7rwkw on the street and aiming for a 'number' is just that... its a number.
You could play with a dyno setting and get 7rwkw if you really want the number to pin to your wall.
Getting hung on numbers is a silly game to get into
IMO the cams, cam gears etc is a waste of money for what you want.
Bigger turbo/manifold/forged bottom end all come first as a stock R33 head is fine under 300rwkw.
But everyone has thier own view as you'll see with the replies that come out.
Hey mate, I just bought a set of tomei poncams for my car. There 256's and I payed about $800 for them on ebay. You can get them even cheaper from nengun.com if you don't mind waiting for ages. I'm still waiting to get my car back from having it's topend rebuilt so im not sure what the power increase is going to be like. My mechanic told me not to bother with adjustable cam gears atm.either. The cams are meant to be real good though they shouldn't stop you getting the power your after.
i was always told that 256 duration cams were the LARGEST u could go, without headwork being done.
is your head still stock?
Yeah my head is still stock.
I didn't want to get cams, but I may as well since it will fix my problem of the 'cam actuator' being faulty.....
Mechanic said that the adjustable cams would fix my problem (i only have 220 rwkw now as opposed to 273, and the mechanic believes its my cams actuator)
go to RB25 turbo upgrade thread (sticky)
compare my car with bombtrack's (same page)
both 25's, same turbo (2835 pro s) same mods, (except cams) same tuner, same dyno. (different day)
i got 265 rwkw
he got 272 rwkw
i get like 5kw more @ 90kph, he gets 7kw more @ 180kph
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
