R32 Skyline Parts for Sale
-Front brake assembly including top and bottom control arms, 4 stud hubs, rotors, calipers, Bendix pads and brake lines.
$200 pair
- Original 4 stud wheels. Also suit 180sx, Silvia and Pulsar. Tyres need replacing
$200 set
- Original Nissan radio $30
- Dash/console surround with cigarette lighter and ash try $50
- GTS-T 4-door door trims with velour trim $100 set
- Centre console $30
- Lower dash trim (under steering column) $50
- Lower left hand corner of dash $10
- Kick Panels $20 pair
- Boot opener $10
- Roof handles$10 pair
- 4-door rear seats with grey cloth trim. In unmarked condition $100
- Matching front seats in unmarked condition $150 pair
Can email pics as currently having problems uploading them.
Parts available for pickup in Wollongong NSW. Smaller items can be posted
Jason
https://www.sau.com.au/forums/topic/232642-r32-parts-for-sale/
  • 4 weeks later...
  • 4 weeks later...
Door trims still for sale? 80$ reasonable price?
Also interested in the rear seats, any better shots of them? higher res?
Also interested in both a pillars, if they are good and in one piece.
  • 3 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
