  • Replies 74
I could realllllly go some food right about now lol. Im keeeeen for tonight :huh::D
-Jack will text you if i need that lift. I tried roll starting my car this morning - didnt even have enough power to do that :( so just jumped it. But yeah trying to get a new battery after school.
Did you try to rolling start it by yourself? That would have looked hilarious haha. Id be getting the alternator checked out asap be4 it does ur head in chazza.
Yes i did Damo...and it didn't look funny because i was parked on a slight incline :( So therefore the car rolled itself somewhat. But yes i guess it was funny in the fact my car wouldn't start :huh: And probably won't either when i try to leave school in 45 mins LOL
I can just imagine you thinking of me, taking the handbrake off, getting out the car, pushing it a lil bit...trying to climb back in the car to put it into gear and then release the clutch LOL
and yeah...6:46....if you get there at 6:45 you aren't allowed in :D
Edited by fullyhyperlite
Bingo :blink:
hehe yes if you get there 1minute before or after they will turn you away...jks lol..i mucked it up and it wouldnt let me edit it again after lol.ok mitch thats kool..i just cant edit your name off the list tho lol.
pritty sure this is dinner at charlies?
hence why are we going to villis?
or are we actually going to villis for tea?
some people said they were going to vilis , and i cant afford to eat out haha
so im just wondering who is gonna be at vilis , i might just come down to charlies and meet up with people
I think its after 7pm at Vilis. I'll be there ... now my tatt appointment is delayed :blink:
Hey, dinner tonight was awesome. Was great getting to chat to you all :(
Cheers to Jack for putting this together only 2 days ago :P:)
Might have to make it a bit more regular and get more people out :)
ah k ,
ill be at vilis from like 7.30 , ill be wearing a black hoodie standing near a 33 with horrid wheels and offset :(
I cruised past Vilis at about 7.20. No one there. Cruised past again at 8.15, still saw no skylines so I went to the city.
haha, everyone knew that stevo wouldn't be there, probably why nobody bothered to show up........he's the major drawcard and life of the party, lol
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
