Also make sure you've done the regular stuff, delete cookies/cache/temp files. Make sure you have no antivirus software that is interferring with anything. Also see if you can get to the site via google
ie. do a search on google for skylinesaustralia and then try and enter the site from the results.
and what about using the link http://www.sau.com.au does that give you the same error?
Though as Christian said, it's probably a DNS issue... what ISP are you with?
https://www.sau.com.au/forums/topic/232823-firefox/#findComment-4085310
