well basically,
i want to do skids lol
and i can get 2 16" gtst rims with tyres 4 free, and these wuld make gud skid wheels for my gts4 lol
what would happen if i ran the car in RWD (by taking out 4wd fuse) and then put different diameter (GTST) wheels on the rear? would it break any of the 4wd computers etc?
Cheers
https://www.sau.com.au/forums/topic/233038-4wd-with-different-diameter-wheels/
Different rim sizes and different tyre sizes front and wheel? ATTESA will be a little confused...
You want to pull the fuse out without disconnecting the drive shaft? Do more searching in the forum, I assume its the same or very similar to an R33 GTR setup
On the 32's you just have to pull the fuse and the 4WD is disabled, so different to the 33GTR that you have to pull out the front drive shaft.
As long as the rolling diameter of the wheel with the tire is the same on both you will be ok.
Agreed, sorry for some reason I thought I saw *R33* in the original post, R32's will be fine the fuse is removed. And R33's you can just disconnect the front drive shaft, you don't have to remove it.
oh ok mint, so if i just remove the fuse so its running rwd it cant harm the computers in anyway like it would if i had different rolling diameter front and back as it would if the 4wd fuse was in
215/45 R17s up front (pizzacutters lol)
205/55 R16 on the back
there is only 5 - 6mm difference in the diameter between the two sizes anyway. it probably wouldn't effect it if you left the 4WD on anyway.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
