R32 Gtr Service Manual 804 Pages Long
  • Replies 43
Guest RedLineGTR
If the server is busy i'm sorry or this server goes down or is removed soon for a temp time. Time and speed and server space costs money and it's probably costing abit of a bitch. Oh well. If it works it does if it dosent. Limited time only as the adds say. But Usally over night its back up again.
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
