I've fitted a couple of different bleed valves and each time it wants to hold close to the right boost in 1st, then every other gear tries to go all the way to 1bar before it hits the fuel cut. Anybody got any ideas as to what this is? Im concerned that if i get an electronic one it may not work also.
Thanks
https://www.sau.com.au/forums/topic/23353-boost-probs/
fuel cut is a bitch! you should be able to get a bleed valve to spike at about 1bar and drop a little under without hitting fuel cut. if you have a standard turbo i wouldnt run it any higher than that anyway. if you have an aftermarket turbo i would get your ecu retuned or buy a fuel cut defender...
https://www.sau.com.au/forums/topic/23353-boost-probs/#findComment-499954
The problem isn't the fuel cut. The bleed valve was adjusted accordingly and no matter what it doesn't hold boost. I set both bleed valves to run at 0.7bar and each time no matter which way i turned the valve 1st gear would hold the boost level desired then 2nd gear onwards would try and go all the way to 1bar. Any ideas?
https://www.sau.com.au/forums/topic/23353-boost-probs/#findComment-501145
hmmm have you tried moving the bleed valve all together, i know my turbosmart valve wouldnt run anything less than 1bar, they arent very good.
otherwise look for a split in the actuator hose, ive seen splits that cause overboost a few times.
first try removing the bleeder, if it still runs over 0.7-0.8bar replace the vacume hose and try again
https://www.sau.com.au/forums/topic/23353-boost-probs/#findComment-501195
nah buy an EBC they control the boost level, basically you tell it what you want to run and it holds the wastgate closed till it reaches that level then opens it.
they are far more precise than a bleedvalve. im ditching my bleedvalve for one now.
im looking at either a blitz SBC IDii or an apexi AVCR both of those give you alot of precise adjustments.
not as cheap as a bleed valve unfortunately :D
https://www.sau.com.au/forums/topic/23353-boost-probs/#findComment-501249
IT may have a 3" dump pipe on there but im not 100% sure, either way it goes straight into a stocko silvia exhaust after that. Where do i remove the stock boost solenoid??? 2nd gear onwards doesn't hold boost at all no matter where the bleed valve is adjusted to. Im just concerned that when i get an ebc it won't work either.
https://www.sau.com.au/forums/topic/23353-boost-probs/#findComment-502960
My friend has a 180sx 2L turbo. he put his on the dyno the other day at CRD and was dissapointed that it wouldn't hold boost either, he has a FMIC, dual stage boost controller, bosch fuel pump, filter exhaust...
CRD put it down the the fact that no matter how high they boosted it, it wouldn't hold the boost because there was a loose spring in the turbo that was soft. so his spikes to 17PSI but drops straight off to 12PSI or so. only makes 153.4KW at the wheels. it should be making more, he is going to change the turbo.
sorry to ramble, just thought if you had a stock turbo that might be the problem
https://www.sau.com.au/forums/topic/23353-boost-probs/#findComment-503529
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
