If they're willing to come out then there's a spot for them. We have a couple of owners with pretty high HP that are very keen on coming along and they only expect one run............ :)
they are expecting 7,8,9,10 second passes?
Nope, they're expecting 1 run in the 10s and then getting kicked off. These are guys I'm trying to get to sponsor the event and it just so happens that they have Supra's as well. They haven't pu the cars on the strip for a while and maybe they might not do it in 1 run but it shouldn't take them too long.
So I have a RB25DET, RB25 gearbox, RB25 diff, its rear wheel drive and i'm an active member of SAU, but cos i don't have a Skyline badge I can't race? lol, good luck getting numbers guys.
Guys/Gals
I've decided to postpone this event until next year. I'm well over my head and luckily I have had some members offer to assist me with this event but there is too much involved to have something like this go ahead this year.
A new thread with an expected or firmer date will be posted sometime in the near future.
Thanks to everyone that provided input, it has been very useful and are being considered for when this event takes off next year.
Thanks again
Ross
Good idea Ross, An event of this big nature needs careful preparation, long lead times for advertising etc.
In the short term, we can always go for a day up to the normal drags, which requires little preparation.
That plus, I need time to obtain sponsors for the event to reduce the cost as there were too many people saying it was too expensive.
Let's put it this way, when this event kicks off again next year, it will be cheaper, but it will also have a completely different format.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
