  • Replies 518
omg no wai
Congratulations, you're currently a silver member, silver being 15 stamps or more. As a reward we’re offering silver members an extra, post-sellout chance to get special Field Day souvenir tickets. Quantity is very limited so it’s first come first served.
too bad i already have my tickets:p
Field Day time up yo!
KILLER STAGE
1.00 Mark Murphy
2.00 Busy P
THEN CENTRE
2.30 Eric Prydz
4.00 DOOM AND Hodratt
4.30 Santogold
5.15 A-Trak
LEFT FIELD
6.30 Late of the Pier
Back to centre
8.15 Boys Noize
THEN KILLER 9.30 for SWITCH!!!
shore thing is too overpriced and fails to deliver IMO...
went and saw basement jaxx and bob sinclair years ago... youd think a 6 hr festival they would each play for 3 hours..
but no some shithouse dj was mixing till midnight then they only played for 1.5hr each..... then it ended at 3am... wtf are you meant to do then!
Ill be partying all night and morning at my mates house party in rose bay NY then backing up to field..... really do my liver some damage!
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
