  • Replies 89
you my friend, are what we people in ''normal'' society, call a f**king neusance!
he's just reposting the shit that got deleted... probably because, i dont know, it was deleted? whats wrong with that? are you saying that if you car gets defected you wont do everything you can to take it off defect??
I for one want to know what makes the 32 and the 180 rare? care to shed any light on the issue red?
that was the most stupid comparison i have ever heard man!!!
thats just like me saying to you, if you did a shit and flushed it, you would do another just to replace it?
:D
guys, guys, please........we're not all wired the same and it's obvious you don't know what's going on here.
Ease up a bit........someone's trash is another's treasure (or art in this case).
thank you
