Formal challenge as posted in the Supra forums
http://www.skylinesaustralia.com/forums/Sk...ha-t233629.html
Of all the events we can challenge the Supras to this has to be the one we have a good chance of winning. The GTS-T's have a great advantage around the track due to their light weight.
We need a good show of Skylines, have a bit of Skyline pride, save up, come out and whip some Supra butt. You don't need to be the best to win a trophy either.
Currently attending
1. a20089
2. Michelle
3. Mark
4. Steady Eddy
5.
6.
7.
8.
9.
  • Replies 133
Currently attending
1. a20089
2. Michelle
3. Mark
4. Steady Eddy
5. Bullet32
6.
7.
8.
9.
I'll be there if my car is ready, its still in pieces after Wakefield but I hope to have it up and going again within a month... (hopefully) ;)
I'll be there to race, but I don't think I will be super quick. The GT-R's have a massive advantage on an uphill launch, and an uphill run suits the more powerful cars. And I will be running street tyres :(
reece as alwas is quitely modest, lol, i should be entering this one, but ill be in the FSAE open wheeler, wooo, ill have my ride there to add to the line tho,
I know some of those Supra boys may have more muscle then PHD's :-), however I'm not sure we can convince them skylines came out in open wheeler configuration.
Its okay, you can double enter :blink: c'mon, support the Lines
interesting yet i still keep saying the skylines and supras are super different cars. the only thing you could compare is a gtst against one or a rwd only gtr. yet would still love to see it. take it easy, stuart (if my new engine is in can i enter)
This event is opened to everyone and is being run by SDMA, all types of cars are welcome but have to meet scrutineering guidelines i.e. safe, fire extinguisher (no plastic brackets), safe rubber/wheels (fit within guard, no wheel wobble). Club is very supportive, you can get your CAMS L2S there on the day and a daily club membership is $10 (you can do this three times and if you want to join after that your 3x$10 can be deducted from your membership).
If anyone has any questions, please let me know and I will do what I can to help out. If I don't know the answer, I'll find out for you.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
