Formal challenge as posted in the Supra forums
http://www.skylinesaustralia.com/forums/Sk...ha-t233629.html
Of all the events we can challenge the Supras to this has to be the one we have a good chance of winning. The GTS-T's have a great advantage around the track due to their light weight.
We need a good show of Skylines, have a bit of Skyline pride, save up, come out and whip some Supra butt. You don't need to be the best to win a trophy either.
Currently attending
1. a20089
2. Michelle
3. Mark
4. Steady Eddy
5.
6.
7.
8.
9.
  • Replies 133
Currently attending
1. a20089
2. Michelle
3. Mark
4. Steady Eddy
5. Bullet32
6.
7.
8.
9.
I'll be there if my car is ready, its still in pieces after Wakefield but I hope to have it up and going again within a month... (hopefully) ;)
I'll be there to race, but I don't think I will be super quick. The GT-R's have a massive advantage on an uphill launch, and an uphill run suits the more powerful cars. And I will be running street tyres :(
reece as alwas is quitely modest, lol, i should be entering this one, but ill be in the FSAE open wheeler, wooo, ill have my ride there to add to the line tho,
I know some of those Supra boys may have more muscle then PHD's :-), however I'm not sure we can convince them skylines came out in open wheeler configuration.
Its okay, you can double enter :blink: c'mon, support the Lines
interesting yet i still keep saying the skylines and supras are super different cars. the only thing you could compare is a gtst against one or a rwd only gtr. yet would still love to see it. take it easy, stuart (if my new engine is in can i enter)
This event is opened to everyone and is being run by SDMA, all types of cars are welcome but have to meet scrutineering guidelines i.e. safe, fire extinguisher (no plastic brackets), safe rubber/wheels (fit within guard, no wheel wobble). Club is very supportive, you can get your CAMS L2S there on the day and a daily club membership is $10 (you can do this three times and if you want to join after that your 3x$10 can be deducted from your membership).
If anyone has any questions, please let me know and I will do what I can to help out. If I don't know the answer, I'll find out for you.
