Item: RB26 Power FC
Age: Unknown
Condition:Excellent
Price: $800 plus post
To Fit: R32/R33 GTR - Can be modded to suit RB20 if buyer is keen, at extra cost.
Contact: Reply or PM
Comments: Comes with Gold 'Limited Edition' D1 Hand Controller
Item: Z32 Air Flow Meter
Age: Unknown
Condition:Working Order
Price: $200 plus post
To Fit: Most Nissans
Comments: Comes with Plug
Item: Exedy Brass Button Heavy Duty Clutch
Age: 1000kms old
Condition:Next to Brand New
Price: $600 plus post
To Fit: Most Nissans - Rb20/Rb25/Rb26/Rb30 - Push Type Clutch/
Comments: Comes with Custom Pressure Plate (Cant remember Specs) & Matched Flywheel (Machined when clutch was installed) -
Complete with all bolts required. and Trust Bearing. Was Removed for Auto Conversion.
Clutch plate has 8.04mm left of material after 1000kms - Exedys listings state they are only 8mm from factory
Thanks for looking. Will post pics ASAP.
Can Post at Buyers Expense.
Can do drop/deliverys in Melbourne Area - PM me.
Do you still have the AFM & Plug - whats the best you can do - how's $120.00 and i'll come pick it up tomorrow cash..
Cos you dont know what condition its in.. Have a think and let me know,,
Cheers.. Im just in FootsCrazy so not far ..
Dee..
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
