looking for e.o.i for after market stagea parts.
7 point roll cage $1300 new
greddy front strut brace $220 new (both 2wd and 4wd)
greddy rear strut brace $220 new
carbon fibre bonnet $1200 new
other parts may be available
pm me for photos and questions
just e.o.i at this stage :(
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/
JUST AN EXAMPLE OF WHAT IT WOULD LOOK LIKE
THERE IS ALSO VENTED BONNETS
C/F $1400 NEW
FIBRE GLASS $1000 NEW
Edited by piratewake
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4099582
good condition white S2 dayz front bumper and rear lip? and roof rack covers (for when you remove them)
D.
by rear lip did you mean rear bar or rear spoiler?
having trouble finding any parts besides spoilers for dayz body kits in good condition, can get brand new dayz dolphin front bars for $600
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4100571
http://www.skylinesaustralia.com/forums/in...t&id=170652
that lip (bolts to bottom of standard bumper)
and if you can find some dayz guard flares ill take em! noone else seems to be able to locate any....
D.
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4101431
oh yeh and momo steering wheels, the factory option ones. im sure im not the only person chasing one of those
and S2 eyelids... i could go all day......
D.
Edited by pintaline
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4101433
D.
bout $600 for a manual wheel second hand
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4101748
D.
s2 eyelids.. fibre glass unpainted $100 delivered
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4103976
the container will get here late november early december. i will be buying at least one of all the parts mentioned above and putting them up for sale when they get here and it will be first in first served. but if you want 2 be guaranteed a certain part you would need to pay for it before october 5th
i can help organise postage or freight but the cost will be the buyers responsibility :(
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4104026
if you can get these eyelids for same price, ill take a set http://page12.auctions.yahoo.co.jp/jp/auction/p119737283
pass on momo wheel, almost half that price thru importmonster
D.
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4105360
i have a dayz kit and would love to get that little lip extension for the front bar. anybody know how roll cages go in a daily driver, im pretty sure u will get defected for that.
https://www.sau.com.au/forums/topic/233763-eoi-stagea-mods/#findComment-4107749
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
