Standard: 2.9/3.1 165/175
Tein: 3.1/3.8 6.8% 22%
Nismo: 3.8/4.4 31% 42%
they are the rates, you can get teins from access autoworks on here, i trust them, have been to there store, no probs.
or nismo's from nengun or RHDjapan.
the whiteline group buy springs on here are just
34gtr front
32gtr rear
Standard: 2.9/3.1kg/mm 165/175lbs/ft??
Tein: 3.1/3.8kg/mm 6.8% 22%
Nismo: 3.8/4.4kg/mm 31% 42%
34gtr front
32gtr rear
corrected, that is for a s1 rs4
hey mate cheers for the reply, but what exactly do those ratios mean?
Those are the spring rates, listed in kilograms per milllimetre and pounds per inch of travel
Example: the standard front springs need 2.9kgs of downward force to be moved 1mm (or 165lbs of force to be moved 1in).
Are the rear spring different for an RS4S? I remeber reading somewhere that they are different to the standard auto stagea.
Thanks
That's right, the RS4S has an R33 GT-R subframe for the rear suspension, and the way the shocks attach to the suspension at the bottom is different between auto and manual Stageas.
Also, RWD-only Stageas have different front suspension because (obviously) they don't need to account for a driveshaft going through the centre of the suspension and wheel hub.
with extra circlip grooves machined on your shocks you can get your stagea as low as you could ever want with the standard springs.
the spring rates on the RS4S seem to be decent as it is according to my bum-o-meter.
if you are buying whiteline springs just specify it is for a stagea.
Thanks, so just to confirm, To lower my RS4S I will need to order R33 GTR springs?
I have been reading up heaps on the suspension thread but there isnt much info on the RS4S
Cheers
Dave
i know theres a fair bit to read in the suspension thread but you maybe should have another look it's been covered to death, sedan springs going on a wagon is a much discussed topic, a bit of advice check out sk's suspension thread throughly....... everything you want to know.... goodluck.
Thanks,
All I am interested in is lowering it a little and want to keep that stock shocks, I have already spend a small fortune on the motor and dont race the car I just wanted it to sit a little lower to clean up the look.
Thanks
Dave
i know the exact feeling.
unfortunately we found the left front shock was leaking so the cheapest option in the long run was to replace the shocks but then we found there was no where near enough camber adjustment on the rear even with an aftermarket eccentric bush. with upper rear camber arms there is enough adjustment to get sensible rear camber settings. so one thing always leads to another...
ps. the rear of the stagea is at 365mm
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
