  • Replies 40
mucking around with more long exp in the car. Dw sidd, i was passenger this time :P. these are the cheltenham rd eastlink for those in melb. nothing spesh
39.
40.
41.
42. a foosball table my mate is reconstructing in his spare time
43.
mum brought me some juice and the camera was next to me and one thing led to another.
man that sounds so disturbing :cool:
on a serious note nice pics.. if you need a nice r33 for a model to shoot let me know i would love some nice pics (poster size) of my car and of course dollars or slabs or any other alcoholic beverages your way for my gratitude.
lol when you put it like that, it does sound odd. regarding the photo shoot, i'd love to shoot your car man. only thing is i think im gonna practice on mine first. i should organise a photoshoot/meet or something in the near future.
awesome, let me know when you are ready :)
here are some pics from the weekend. all the cruise shots and the filter are taken with the 50mm. i dunno bout the other because i was changing between the kit lens and the 50mm through the night. the 21st went well. realise i need a good flash.
44.
45.
46.
47.
48.
49.
50.
51.
52.
an impromptu shoot while i was at uni. didnt even wash the car. excuse the crappy quality. lost something in the uploading. however when i was reviewing the pics on the comp i noticed a bit of lens flare and a lot of softness. i dunno bout the flare but am i right in thinking that shooting with a smaller aperture (bigger number) will result in a sharper pic?
53.
54.
55.
You can see the flare coz you are pointing the camera straight at that light bulb.
Also f8 is about right for those night type shots on your stock kit lens. Im assuming you are using stock lens for these shots?
Also perhaps try and get the whole car under the light. So there will be no dark spots on the car. Your car is already a dark color.
I like shot two the most :( keep it up!!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
