I'm coming up with a design at the moment Steve, and I'll work through it with Daniel. I basically want a rectangular unit that will fit into the spare wheel well, with a perspex removeable lid, like the one attached.
sprinter boot isnt it?
mate made one for his brothers ae86 running the 1JZ - curved surge tank to match the wheel well and had the lines exiting the side of the well, then sealed up.
33 boots are not round like the pic above, they are more square and have a step in them that would make the use of a single sheet to cover it bulky.
get a torch out and lightly heat it so you can bend it.do it one more time to finish the step. worth a shot :)
Hey Chris, the example was a sprinter boot, and the champagne coloured boot is a 180SX boot, which is what I want to get the enclosure made for.
I have a small, square surge tank which is only about 150mm high so I could fit it into that area.
  • 2 months later...
hows this coming along?
i need a new little project to make up at work?
i just need to knwo what it consists of! lol
we just wanted to replicate the one in the first post. Just alloy sheet folded n stuff with a perspex cover. and a few fittings welded on so the fuel can get in and out and the smell stays in.
Chard on here was going to make me one, but due to issues at his work has taken too long so I'm looking at more sources now.
I'm speaking with Daniel (Activ32), but if you want to make it Blaq let me know.
This is what I'm after, but dimensions can change slightly if it would suit more people. Just an ally box with a perspex lid, pretty simple.
So whoever want to do it let us know! Car is nearing completion and I want as soon as I can get it done for a reasonable price.
Just measured that up in my boot and that box is huge, i will most likely want only want a 300 deep, 450-500 wide, (what ever height a std surge tank is ??? 400-450),
with 3x jic male to male fittings welded in the side.
I spoke to my mate today that does all folding and cutting i need in alloy, he is willing to make these, with lexen lid or folded section like original picture.
About $175 each for the dimensions given by Phunky_monkey - plus shipping to Melb of course.
all folded , welded, recessed and Nut-serts and Allen key bolts.
Ryan - no need for the male to male fittings as that defeats the purpose as the connections are still outside of the box.. but can be done if you get the fittings needed to pass through 2.5mm alloy
Chris, thats cool but whats going to stop the smell getting out? The hoses will still need to go into the box some how. If you use proper jic fittings on the correct hose you will not get any smell outside the box.
then technically you dont need a box then :ninja:
the whole point of the enclosures really is for legallity - they must be seperated from the cabin by something... so if you have exposed hoses, your not going to get away with it on an ADR perspective. the correct hoses would remove fuel smell by default.
are you using JIC and not AN fittings? havent really seen JIC available many places.
My own system is mounted along the boot where the battery used to be, i'll be flanging it down to the stock fuel inspection cover so its totally sealed from the cabin, without anything exiting the sides of teh enclosure other than wiring.
any way you go, you will need to run grommets through the side of teh box, Jaycar have some great 3 piece screw on grommets than are waterproof (so leak proof for vapor)
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
