Evening,
Just searching around and found a page containing some text naming a turbo called Garrett 35/82 SPL.
Now i've done a quick search and have found nothing as yet.. (hopeless web surfer i am)..
So just curious if anyone can shed some light for me, answering here or perhaps giving me a link..
Cheers,
Gordon.
https://www.sau.com.au/forums/topic/234505-garrett-3582-spl/
Evening,
Cheers,
Gordon.
link to said page plz
Be sure to search :down:
A GT3582 is the proper Aussi term (diameter of the compressor exducer) for a GT3540 (US measure the comp wheel inducer)
Garret dont market a SPL AFAIK, what you could be looking at is a GT3582 with a T04R (66mm ind) front wheel placed into the machined front cover.
From memory they are worth another 40hp worth of top end flow. Searching will tell you some ppl don't advise it, at the exhaust housing borderline with the stock comp wheel as is.
I have one with another click worth of work that I believe should offset that issue.
Course, i could be way off :P
Edited by GeeTR
sounds like a GCG thing to me..
i had a bloke try telling me about a T04z SPL and SPL2 a little while back.. and i told him there is no such thing.. did some researching and it turned out that GCG nicknamed a standard t04z with split pulse ex housing and ported comp cover the spl and the spl2 was the exact same except had a ported 0.8comp cover
so i'd say it'd be something similar to that.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
