FOR SALE:
R33 GTR Standard Rims with Tyres 50% Tred: $1000 ($1150 Delivered Anywhere in Australia)
R33 GTR V-Spec Factory Suspension (With Nismo lowed Springs): $350
HKS 3037s Twin Turbo Kit (Full Kit, Straight Bolt On to RB26): $5000 ($5150 Delivered Anywhere in Australia)
R33 Gts-t Factroy Side Mount Intercooler: $50
Xforce Stainless Muffler (Twin Exit Pipe): $100
R33 GTR Apexi N1 Coilovers: $700
Please PM Me About Items, If you Like Something That I Have Advertised Drop Me a Message!
Edited by F u r i o u s
I'm willing to send the parts anywhere in Australia
*R33 GTR V-Spec Factory Suspension (With Nismo Lowed Springs): $350
Any chance these will fit an R33 S1 GTST?
Edited by Samon
I'm not 100% sure but you might wanna look into that
Wont fit mate.. 33 GTR uses same suspension like R34's... :P
otherwise these would be in my garage now..
Thanks!
Items Left For Sale With A Price Drop!
*R33 GTR V-Spec Factory Fuel Pump: $90
*HKS GT3037s Twin Turbo Kit (Full Kit, Straight Bolt On to RB26): $5000 FREE POSTAGE
*Xforce Stainless Muffler (Twin Exit Pipe): $90
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
