Make: Toyota
Model: Corolla Seca Liftback RV
Milage: 120,000 origional kms, with service history!
Transmission: 5sp manual
Colour: White, faded, couple of light rust spots, nothing touch up paint wont fix
Complied? Fo shu!
RWC supplied? Ill write on paper if you want
Currently registered? YES! Till November! Rego is cheap as piss on this too
Price: $1800 or Best offer... Chuck me an offer dammit!
Contact: Myself, drop us a pm and ill chuck you my number
Comments / Modifications: Its pretty damn clean inside, its got a panasonic cd player and some 6x9s on the back fully sick, couple of rust spots here and there, otherwise its a toyota so starts first time every time, service history, and PIRELLI tyres that are almost new! WOW
It will make a great runaround for someone, it can run on the smell of a fart, plenty of room in the back for bodies or car parts, do petrol runners in it, take the springs out and crooz george st.. whatever!
One issue, it bumped into the back of a stationary car doing all of about 7km/h so it busted a headlight and bent the bonnet, but this ONE TIME DEAL i have put new headlights on it, and another bonnet, which is slight different colour but still looks hot, paint it black for drifter look! the raid support is slightly bent, but there are NO leaks, EVERYTHING still works.. its shit hot...
Images: Sorry no images as yet
BUT it looks like this one without the gay bonnet scoop and stickers
https://www.sau.com.au/forums/topic/234665-toyota-corolla-seca-1993/
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
