Make: Toyota
Model: Corolla Seca Liftback RV
Milage: 120,000 origional kms, with service history!
Transmission: 5sp manual
Colour: White, faded, couple of light rust spots, nothing touch up paint wont fix
Complied? Fo shu!
RWC supplied? Ill write on paper if you want
Currently registered? YES! Till November! Rego is cheap as piss on this too
Price: $1800 or Best offer... Chuck me an offer dammit!
Contact: Myself, drop us a pm and ill chuck you my number
Comments / Modifications: Its pretty damn clean inside, its got a panasonic cd player and some 6x9s on the back fully sick, couple of rust spots here and there, otherwise its a toyota so starts first time every time, service history, and PIRELLI tyres that are almost new! WOW
It will make a great runaround for someone, it can run on the smell of a fart, plenty of room in the back for bodies or car parts, do petrol runners in it, take the springs out and crooz george st.. whatever!
One issue, it bumped into the back of a stationary car doing all of about 7km/h so it busted a headlight and bent the bonnet, but this ONE TIME DEAL i have put new headlights on it, and another bonnet, which is slight different colour but still looks hot, paint it black for drifter look! the raid support is slightly bent, but there are NO leaks, EVERYTHING still works.. its shit hot...
Images: Sorry no images as yet
BUT it looks like this one without the gay bonnet scoop and stickers
https://www.sau.com.au/forums/topic/234665-toyota-corolla-seca-1993/
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
