I have just been offered a good deal on multiple sets of these coilovers, but 3 sets are needed to get them at this price, they retail for almost double this
What: R33 & R34 Bilstein PSS9 Coilovers
Price: $2200 +$50max postage aus wide
When: As soon as 3 people put a deposit down, they are in Aus, so 1 week to you door max
Who: Contact myself via PM, Email or phone ~ [email protected]
Height and dampening adjustable, roughly 30-50mm drop is possible, inverted monotube design
Bilstein B16 – PSS9/PSS10 System
This “race inspired” system provides the ultimate in high
performance tuning. The manually adjustable damping
monotube gas shock absorbers feature 9 or 10-stage
precise compression and rebound settings, from comfort
to competition. The threaded body allows accurate
adjustability of the front and rear progressive rate
springs to achieve the vehicle ride height,
center of gravity and
level of performance
handling desired.
The Bilstein B16 system puts
you in complete control
providing the kind of precise
suspension tuning formerly
available only on race
cars. From a weekend of
competition to daily
driving, this system
provides perfect
handling
performance for
every situation.
Image below just for reference
For any more info just ask, I dont come onto these forums that much, but i will check back soon
https://www.sau.com.au/forums/topic/234685-r33-r34-bilstein-pss9-coilovers/
Sorry they are for R33 & R34 GTRs only, they never did a pss9 for R32 or other gtst, ot that is still available today at least
But don't Bilstein do a coilover for the R32 GTR. I thought they did only recently. It wasn't a pss9.
I remember seeing it advertised for around the $4000 mark complete set.
I think they are 400lbs Front (approx 6 or 7kgs) and 450lbs Rear (approx 8kgs).........I'd prefer the other way around if possible.
Jude (CAZMAN) needs to confirm this though............soon I hope.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
