haha naa all good just been chilling with a mate who just let off a fire work in his hand haha
but anyways its coming from the engine bay sounds like metal whining then stopping
Gotta love fireworks/crackers.
I actually have this problem too! that's why I first went into this thread. Totally forgot to talk about it. haha.
But sometimes I also get it when when the revs go a bit higher than idle like if I turn the climate control on. It's wierd.
I thought it was my timing belt that was too tight coz I put a new timing belt kit in even before I had started the engine the first time (I bought the car not running). But It's still doing it and I've done about 3000-4000kays.
shit u guys where right about that whinning comming from the missus " ur always on that skylines thing blah blah blah" haha :banana:
lol, i get the same thing mate dont you worry....
tell her to get a hobby!
didnt work for me but its worth a try! lol
I've been told it might be one of the cam gears or the belt itself just rubbing on the belt cover. Coz at that certain rev, obviously just b4 it stops, maybe the cam gear or belt move slightly or vibrate. Haven't tried it tho.
Edited by Fabs_32
yeah.......after it has turned off, the turbine doesnt all of u sudden some to a complete stop!
it spins freely for a couple seconds before sloooowwwwlllyyyyyy stopping :banana:
well thats my theory any way.
case closed!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
