Item: R33 GTST Power FC with Hand controller
Age: 2 years old
Condition: Good, few scratches on the HC screen.
Price: $1100
To Fit: (What car) R33 gtst
Contact: PM
Comments: Has a $600 CRD tune on it to suit FMIC, Z32, 3" exhaust, make 219rwks at 13psi (stock turbo) perfect cold starts,
Item: Ganador side mirrors blue mirrors
Age: donno
Condition: goodbut has a few chips, painted in Gun Metal Grey
Price: $370
To Fit: (What car) R33 gtst 2 door coupe
Contact: PM
Comments: Bought these second hand..
Item: Z32 AFM with Tomei plug
Age: 1 year
Condition: Good, mesh is perfect and so is the eliment.
Price: $220
To Fit: (What car) anything really.. its a 80mm AFM so some cars may need new pipes. This is a direct replacement for R33 with aftermarket ECU.
Contact: PM
Comments: no need for it anymore..
Adam - pm sent..
Ron - No probs mate, the buyer seems genuine to me though mate.. He has arranged pickup for tomorrow. I will let you know either way.
Cheers,
Johno
Lol, "gazumping" doesnt work with me..
I made a gentlemens agreement with the buyer and I intend to meet it. If he falls through it will be offered to /2on and so on..
All good man i beleive in a good old spital hand shake to.. lol
one of them dont work? electric wise
Not sure that you mean...? If you are refering to the Ganadors they work perfectly.
Cheers
Johno
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
