Does anyone know where I can source an R32 Gtst DoLuck kit in perth ? I have found an interstate supplier with help from Flash89 (cheers :)) but hoping someone knows of a WA based seller so I can try and avoid hundreds of dollars of shipping costs.
Cheers
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/
Not sure if ur after genuine, but Fibrevision can make it up for you. They're gona do my Origin kit coz yet again the resellers give me a quote and don't get back to me after I tell them I want to go ahead.
Which reminds me has anyone got Bruces number I need to give him a call about my kit. Had it on the old fone. Thanks :)
Edited by Magic
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4117123
Fibrevision
38 Banksia Rd Welshpool 6106
(08) 9458 8998
Tell him Brandon with the 34 gettin the Origin kit sent ya. :)
Ima go in 2moro, heck might even leave the car there and get him to do it ready for next week drags.
Edited by Magic
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4117531
I got to ask, with this fibrevision do they have the kits in stock or do you just tell the guy what kit your after and he can make it up for you and fit it? Do they also paint?
Both, in my case they have the side skirts in stock and will be making up the front/rear bars. They also do spray and fitting.
Also, if you do go in, ask to see their portfolio of show cars, you'll be impressed. Expensive work but, I'd rather pay the money and know it's going to be perfect.
Edited by Magic
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4117948
I got a Do-Luck front bar for my R34 from DMD. They are over east though. I'm pretty sure they have the kit for R32's too
Just google "DMD The Image"
isnt that monkey warehouse ?? I checked out theyre website but it doesnt work for me :S
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4118155
I got my r33 do luck kit from dmd, had it fitted and sprayed by fibrevision. So i would recommend trying dmd 07 3344 1818. Make sure they pre fit the kit before they send it. They appeared to have cut corners when they made mine which just created more work for bruce & brandon at fibrevision. Dmd are very well priced
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4118422
Got a do-luck boot cover thing for my 33 from DMD. Didn't fit the way I planned so it had to be modified and ended up costing a fair bit. Might be worth talking to Fibrevision to see what they can do price-wise because if you end up having to modify things it may be cheaper to just get them to make it the right way from scratch.
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4118810
Fibrevision get their kits/moulds from Monkey Warehouse if they are too busy to make it up themselves. Shipping on kits is roughly about $300 extra,depends on the kit of course. May as well pay fibrevision the cash and let them worry about shipping etc as it'll go straight to their shop.
I stopped in their today, My kit may be coming from QLD because they are quite busy at the moment. only about 7-10 days shipping but. kits is costing me roughly 1.7k-ish and spray/fitting is about the same.
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4119396
We have a R32 Do Luck Kit in stock, however once again we are on the east coast (Melb).
Is it for a GTR?
nah gtst mate, cheers for reply.
I tried calling fibrevision all day but i guess theyre busy lol, either engaged or didnt answer :S
https://www.sau.com.au/forums/topic/235082-do-luck-r32-kit/#findComment-4122190
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
