  • Replies 44
Hi Guys!!!
I have 1994 S1 R33 GTST complete for wrecking, car is still complete and running due to i cant sell the complete car and i really needed the money so im going to have to wrecked.
Car had just over 100 000 klms on clock been sitting for a while now. Car is gun metal grey in colour. Car is complied.
Engine complete r33 series 1 (standard) with 100 000 klms on clock $2000 harness ecu turbo .
Complete 5 speed conversion gear box and the rest $2000
Front windscreen $100
Rear windscreen $200
Side quater window $50 each
Standard fmi with pipe $50
Cat back exhaust $200
S1 AFM $115
Quick shift kid $100
climate control $50
charcoal cannister $30 (smaller size type)
ac Fan $80
hub/fan $150
Radiator $150
rad. shroud $50
Condensor s1 $100
gaurds $100
s1 front bar $200
Front bar enforcment support $150
bonnet $250
side skirts $150 pair
s1 cluster $230 with 100 000klms...
s2 front grill $100
rear tailghts $250 complete
rear bar $100
rear garnish $70
Rear pod $80
Doors $50 each
Window motor $140
Window maganisium $50
Front Lh, RH glass $60 each
Door mirror $70 each
boot lid $100
s2 boot spoiler $150
drivers window switch $120
Passenger side $60
complete interior $200 minus rear seat......happy to separate seats trims etc.....
Adjustable coilovers $900 for the set fronts and rears
Rear diff $400
rear / front lower control arms $100 each
R34 Gt rim a set with good rubber $300
complete 5 stud conversion $800..happy to separate suspension also..........
happy to separate the shell eg Radiator support, rears quaters etc.
PLEASE ASK IF I LEFT ANYTHING OUT.
there heap of parts left.
dinzlr/khmer whatever... you were banned before.
You've been banned again. Stop signing up fool.
Anyone doing dealings, or thinking about it - should cease with this person
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
