yeah sounds a bit too high, my 34 with exhuast, fmic, ~9psi, pod makes 185rwkw, so id guess on 11psi ish youd be at 185rwkw-190rwkw. how have you achieved that boost increase?
Jeff at turbo tune said something on the lines of the stock solenoid has a high and low setting. Mine started at 6 psi and then made its way up to around 11.5. When I get the dyno sheet scanned you'll see where the boost increase will be.
  • Replies 54
auto salon was dead on actually. i had just got my car dyno tuned at boost worx a week prior and it made 2kws more than it had been tuned for.
anywho.. i dont find it hard to believe 200. i mean 11.5 is lot of boost for a rb25.
The Autosalon dyno was the Graham West dyno, yeah?
correct cronic.
Zak, yeah you've got a real gem of a 33 there, seems your fmic and exhuast is working very nicely with your engine.
And Steve, i was just asking how he achieved the boost increase, a jump to 11.5psi from just minor mods isn't seen too often.
Edited by Damo_R34
yeah i edited that, it came out completely wrong lol. 6psi sounds like a fair gain in boost, i wouldn't mind having mine looked at. Guess i'd start with hi flow/no cat and removing the restrictor.
201 is a too me sounds about right.
i made 205 with the same sorta mods when i had me ebc fitted and set at 11 psi...
got alot more now though :P :P
Edited by craig R33
he wont be able to add it now Dale, you have 10 mins to edit your post unfortunately. Has a nice increase at 150kw's, Jumps to 170!
I think you'll find that that is AFR related. the factory maps are a bit all over the place as they are only tested at certain points in the rev range not over the whole range. So at the points were they are tested they have good emission's and every where else it's tuned for safe power.
Zac has an SAFC II in the car but it hasn't been played with at this stage and has 0 correction factor at every point so when he takes it to Jeff next the AFR's will be more constant and there will be a bit more power (~10kw).
P.S. thanks for letting me know about the editing time, I never could figure out why you could edit your post some time but not others. On NS where I do most of my posting you can edit it any time. I guess it pays to be a post whore on more than one forum.
Edited by D_Stirls
wheres the Dyno settings at the bottom Dale
i thought it was more like 30mins editing either way we need editing rights
I'm not sure where the info is, I just checked the printout and it's not on there.
But I also looked at the printouts for my car that were done on the same dyno and there aren't on there so it might be the way TT have there printouts setup. I would say the the temp are correct because every time I have seen Jeff drive a car on the dyno the first thing he does is enter the humidity and temp from the weather station they have setup next to the dyno.
Ive been in and driven IZZMO 33's car and it feels very much like 200+rwkw with minimal mods aswell..very impressive.
to me that dyno is reading a wee bit too high
i had my car dynoed at Willall Racing and they use a mainline dyno
with a front mount, boost increase to 9psi, full zorst, splitfire coilpacks, pod....my car made 188.7 rwkw on a reasonably warm day
so from the mods that you are saying you have i would expect the same sort of power that my car has pulled out
plus no boost controller and ur hitting 11.5psi....umm have you had that reading out off a boost gague or from the stock gauge.
My R31 with series 1 rb25det and my r33 with series 2 rb25det both made 203rwkw and 205rwkw with 10psi, cooler and exhaust on a few different dyno's give or take 3-5kw
You WOULD have about 200rwkw if there was an aftermarket computer or your ecu has been remapped........
not necessary mate. Every car is different.
over 30 posts and no one has mentioned ramp rates.
how much brake against the rollers.........you need to compare apples for apples
God dam it pete, you beat me to it! hehehe
People dont realise that its up to the dyno operator to choose the specific ramp rate that the dyno produces...this alters your power output...usually a standard ramp rate for these things is around 150.
So many people are quick to assume every car is the same and will make simular power with simular mods. Every car is different. So many variables come into play when it comes to output on a dyno...remember people its just a number.
Edited by Ryanrb25
oh and i forgot to mention we've had plenty of 33's on the dyno at Aussies and alot of them make good power (190-200rwkw) with basic mods yet others make average power (160-180rwkw) with simular mods...SO many variables. Believe it or not other cars have had a much harsher life than others.
Edited by Ryanrb25
and some over 300rwkw Ryan...lol
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
