No RNS11Z its from a white series 2 with internals,tomei cams, greddy plenum and a td06 25g
I made just over 400rwhp at a touch over 15psi and have now had the car tuned with a power fc, why do you need so much boost to make less power, maybe the td06 is worth the extra $$ hahaha
  • Replies 73
Well considering i dont have cams and cam gears, once i get the bigger injectors and bigger fuel pump 440rwhp will be easyly made. The reason why i had to use such high boost to get the power levels its at now is because of my fuel problem. If i were a mechanic.. hey id solve the problem myself and tell you the reason why its not making so much power.. but im not so thats just the way the cookies crumbles.
As I said in another post, the type of dyno used does matter. I read in a Fast Fours that the JUN s15 in Perth pumped out around 700hp (???) at the wheels on one dyno, only to produce a comparitively measly 550hp (or thereabouts) on another dyno. Well, actually it's still damn impressive but not so much when compared to the 700hp figure :O Best is to have a dyno day shootout for comparisons sake.
Generally dyno's do not vary that much.
Most of the time they are within 20rwkw of each other.
Well in Adelaide they are. All depends if they were both running the same mode etc. I think it is shootout mode that takes in to account temperature etc is it? If so that is the one that should be used.
RNS-11Z,
i'd like to know what exhaust housing you have with your GT35 as this in itself would restrict the amount of power that you'll get from your engine.
for eg,
the GT35 with an A/R .63 exhaust housing (714568-0003) is rated at 550hp whereas the core itself is actually rated at 600hp.
http://www.turbofast.com.au/GTseries.html
btw, does the turbo boost/power come in pretty quick or is it reasonably laggy?
Tune can make a HUGE difference. I was getting 230rwkw at one dyno - four hour tune, 257 at another days later - this was just a basic 'interim' tune (until gaget and cams) and it took less than an hour.
martin donnon explained that the only way to accurately compare dynos is to use shootout mode, and punch in the figures measured in the dyno bay at the time of tune - otherwise its not really an even playing field.
Out of interest, the correction on the day I got the 257kw tune, was only 1.029 so bugger all anyway:p
True, Steve does about 50% of SAUWA cause he does a great job, and doesn't bullshit us.
It seems that all of our turbo's are making similar levels of power, but making the power quite differently. It will be interesting to see what happens when we all push the turbo's harder.
Thanks for that site RS500. Much appreciated. Yes it is laggy but its just the way i like it. The part no: on my turbo is FC 6027J then its 706451-5. With a .7 A/R rating front housing (if i am correct but it has .7 stamped on the front housing). Not sure the size of tge rear if its .83 or 1.06 or .63
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
