Hey guys, bout time I got rid of some stuff thats taking up place in my garage...
HKS Mushroom Pod Filter - You all know what these are so don't need to explain much - $50 ono
2 x Single 2.5" into twin 3.5" upswept exhaust tips - few minor scratches all on the under side, had these on for four weeks then had to change due to body kit. They look very tough - $30 Each or the pair for $50
Polished stainless muffler Single 2.5" IN twin 2.5" OUT - came of a mates car has a very nice note to it - $50
R33 skyline DeCat pipe with Sensor fitting - Had this made up for my skyline no longer required, it was made for an R33 but might suit other cars not sure - $50 ono
Trust Muffler off my R33 3" in with 4.5" Tip - This is a genuine Trust muffler and has an awsome note to it plus has the larger body (not a cannon) which makes the car fairly quite at low revs but when you get into it sounds awsome - $95 ono
Genie Cannon 3" in with 5" tip - This cannon is massive and sounds insane plus looks awsome had it on my R33 and definetly stood out - $95 ono
Pair of R33 tail lights - Good condition don't really need to explain much - $40 each or $70 for the pair
Set of Series 1 R33 RB25DET Coil packs - Working fine when removed from car, removed due to rebuilding whole motor and putting external coils in. - $30 each or $150 for the whole set
RB25DET Tommy Kaira Engine Cover - came from my motor but due to going external coils could no longer use looks awsome and really sets of the engine bay. It's fully cast - $200 ono
R33 Series 1 Nismo Wing - painted marron and no damage, It the one thats a bit higher than the standard one and sticks out over the back of the car - $100
Sony Rear Projection TV 68cm not widescreen - $50
Benq 17" LCD monitor - $50
Geforce Graphics car for computers - Great upgrade to a standard system - $30
I'll get more pics if anyone wants something in particular
Contact me via PM, need to get some funds for this weekend so if theres somethin you want give me an offer and i'll consider it
https://www.sau.com.au/forums/topic/235769-garage-cleanout/
  • 1 year later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
