hey guys last night i became the proud owner of a '97 rs4 and all was going well, took it for a boost up the express way absolutley loving the power delivery and ride comfort, tore around a couple of back streets good stuff.
anyway I was almost home down a back street when upon accelerating hard and hitting 60kph my speedo, tacho and fuel gauge cut out and just went to zero as if the car was off, now the strange thing is the car was working fine still speed up and slowed down with no issues.
got home turned the car off left it for a minute and then turned it back on but the gauges still didnt move. went inside and called the previous owner and he said he had never encountered this issue.
went back outside turned the car on and then all the gauges were working took the car round the block and everything was peachy..
anyone encounted this issue before? what do you think the problem might be?
I find it a bit suss that the car is 11 years old with no issues and i have it for half an hour and something goes wrong.
any help would be greatly appreciated
https://www.sau.com.au/forums/topic/235775-weird-issue/
like mike said, undo all connections off back of cluster and re-attach them, also could be a bad connection in the fuse box, pull all the fuses out and push them back in. Spray all of the connections with a contact cleaner if you want to be fussy.
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4128437
Did your warning lights come on? Did anything else happen or just the gauges died.
if your warning lights started flashing also, then I'd be saying your getting low voltage problems. Check your battery condition.. you'd be surprised how many issues stem from a bad battery!
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4131569
sorry its a bit off topic, but just reading about how to get the steering column shroud off, i was wondering if anyone has installed a turbo timer them selves.... I'm just not sure whether to try it myself or just get an auto leccy to do it...
Cheers, Bradd
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4132518
Cheers, Bradd
Mine was already in the car but if you are getting a brand new one it should come with wiring instructions and you can have alook and see if it means anything to you and if not a sparky should be able to do it in 30 mins (or phone around a couple and ask for a price).
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4132583
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
