  • Replies 93
Originally posted by hippy
all this talk of beer and highly modified cars??  LOL they don't mix well  :D
Hippy, how could you say that! havent you seen F&F? lol
Paul, sounds good;)
Think I better ring the park and find out if they will be/could be open at that time:)
Originally posted by EnricoPalazzo
Gts-T VSPEC: what sort of beer do you drink, i only drink Coronas, so u better bring those! HEHE
Brings Coronas & Crownies for me too Paul :uh-huh: :)
Bl4cK32, hopefully it will be a lunch time thing too. I just spoke to the guys at the track, apparently they are doing a sausage sizzle and so may not like the idea of us doing the same - might be a anything execpt sausages.
T-man, how hard would it be to organise a rissole sizzle?:P
I will find out more on Monday.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
