well guys i just thought i would say i got a new car to day, a 199 R32 GT :cool: S25 4dr with a series 1 RB25DE :down: .
the came with 16" amg rims and a aftermarket exhaust to what i dont know maby 2.25" in size but sounds grate any way.
the car is black with only a dint on the roof. and alsohas a spoiler.
however proplems so far:
i found out why people hate the HICAS on the way home, it will go and 2nd
i have to rev the car to get all the electronics to work (dash, interior lights, and windows) it even jamed the auto in park and i couldn;t find out why and till i got home on the tow truck.
any one know about this problem
https://www.sau.com.au/forums/topic/236016-my-new-car/
Charging would be a band aid solution.
You could always buy a centre guage ammeter, you should see a positive charge when the engine is running, if its negative deflection that means the alternator is not providing enough voltage to keep the electrics 'online' hence causing a power drain from the battery...
buy a bigger alternator...
https://www.sau.com.au/forums/topic/236016-my-new-car/#findComment-4134612
ok well im am stripping the car soon
https://www.sau.com.au/forums/topic/236016-my-new-car/#findComment-4134635
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
